Sonnax Edelbrock TV Cable Corrector
    Anyone use this before and did it help?
    The Best
    They don't fucking work.
      Watch me make my own when I get there.
        Well shit man i will be watchin ya so i can make one.....When i get to 85 it like damn near having a new car with a govenor its just holding me back from all the power my engine has.. You can hear the car reving up like it wants to run like a raped ape but wont go..And the tranny doesnt have any problems....It has to be the tv pressure of the cable setup throwing it out of wack.
        The Best
          If you have a computer from a automatic car its part of your problem they have a spark retard built in get one from a manual trans car.
            He's got a 4bbl and an MSD box. No spark retard or computer mess involved. The EFI parts were removed months ago and have been since sacrificed to the graveyard known only as Skip's scrap pile.
            Nate, is it in 3 or OD at that speed? Do you still have all 4 gears? They won't kick into overdrive at or near WOT either, so its possible its winding out as much as its gonna with the current carb tune.
              My bad. Loosing it working to hard. Regardless I will do it but most likely on a dual quad setup might not work on a single. Havent designed my linkage yet.
                Whats been done to your engine. Hyd rollers dont go much over 6000 because eof there weight and lower spring pressures than solid rollers. A 302 should see 6 though.
                  Lokar?
                    Yea its a lokar setup I have a 351W with a 4 bbl edelbrock.....I was driving the Vic last night and like i said when i got to 85 it felt like i have a damn govenor....Before 85 mph its all ood car rolls out wit no problems what so ever....Gadget i will let you test drive it when i get up there friday so you can see what im sayin....
                    The Best
                      He has a mild cam and flat tappet hydraulic lifters. Its not a radical motor but it runs real strong. I've driven it, but never over like 60 mph, so I'm not sure what it does when its pushed. I know at cruise speeds it goes.
                        That kid you put up above is for the Holley carb with an AOD? I thought that was needed to get the geometry right.
                        ~Adam
                        '85 2-Door Crown Victoria
                        302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
                        '04 Crown Victoria LX Sport, '02 Jeep Liberty
                        '83 Suzuki GS 1100E Motorcycle[/color]
                          Well by Sonnaz site its suppose to correct the Geometry for a AOD using a edelbrock/carter carb...
                          The Best
                            The geometry appears correct on my 1406 and Lokar combination.
