This has been going on for a while but is getting worse lately, when ever my merc hasent been running for a couple hour's or over night when i start it the rod's knock for at least 15 seconds, i did an oil change a couple months ago, went to canadian tire told them what i needed oil for and they gave me 5 W 30, im not sure if that kind of oil is to thin?? My car only has 160,000 Km's on it, so i hope it's nothing major, the engine runs nice and quiet after that 15 seconds though,,.
Rods knocking on start up!
5w is a bit thin, Hopefully runnning a thicker oil will make it go away since its only for the first 15 secs
Ditch the 5w. We fixed Fordgirl's Vic with 20w50 and a quart of Lucas. Engine is nice and silent now.86 Lincoln Town Car (Galactica).
:stupid: For now, I'd run 20w50 like gadget said since its still summertime and it may help alot. For the winter time I would drop to 15w40 or 10w30 with an additive. Running an additive is a great idea, I used both rislone and lucas in the past and both would make the knocks and valve chatter disapper.
Also, its pretty normal for a high mileage 5.0 to have low oil pressure, so on a cold morning it may still have a slight knock. Seen plenty of these motors see 200k or better with a low oil pressure and even a slight knock. When your engine light comes on and you have a constant 0 psi at idle, then you have a problem.Current rides - 1991 Ford Thunderbird 3.8 v6 (gas saver/DD) - New Heads/Headgaskets with ARP studs, Air Silencer Delete, 70mm MAF, Plasti-dipped Matte Black with a Silver Metalflake Overlay, Muffler Delete, some LED's, 30.233 MPG for high MPG average!
Associated Panthers:
15w40 here and no rattles. Also I use a smaller oil filter as it takes less time to fill up. I think its a motorcraft fl400.1989 Grand Marquis LS
I have used Shell Rotilla T for years in most of my cars 15w- 40w. This is now one of the few oils that will still support flat tapet cams. Of course most of us run rollers. If you need something a bit thinner for the winter add a quart or two of a synthetic in it.Scars are tatoos of the fearless
I am a firm believer in rotella-t also. I go like 8-10k between oil changes with it.1989 Grand Marquis LS
