Hey guys i been thinking, and reading... Thats scary....
Any how i been reading in my Shop Manual. And it's got this thing about figuring Probulems with car's It's some sort of sheet. And it makes you think...
Any how, to sum all this up. I Thought about when my car started acting up.. Becase it didnt do it when i bought it. And this is what i was doing to it when it started to mess up.
#1 I changed the dist cap and rotary button
#2 I changed the plug wires
#3 The first thing i did to my car was put 10$ or premuim gas in it. ( When i bought it
#4 I kept getting Premium gas and Fuel cleaner and added it to the gas.
#5 i changed the PCV
Ok, So now What i have done To try to fix the prob is.
#1 Went and bought brand new dist cap and rotary button, plug wires
#2 Set the timing
#3 Found out i didnt have a carb and used fuel injector cleaner
#4 Found out preuim is bad for my car and started useing reg.
Ok, now Im adding this up in my mind, ( Like i said it's scary
) ) aNd the only thing i can think of is....
My Carb is fucked.! or the Injectors, or something... Fuel Related...
Any thought's on this? I almost got it pin pointed to umm the fuel due to i made a post one day after i filled up with premuim, About it rattel around in there and popin,then blaming it on a bad plug wire...
Any how. any thought's are welcomed. How to test for it anything
Thank's guys,
Dark
O yea, i know you gonna ask. My injectors on the left side as your looking under the hood, makes a Poof type of burst of fuel, and the right side. makes a stream type of fuel come out. Does this mean anything? Thanks agine in advance :->
#2 Set the timing
Thank's guys,
Dark
