Air Bags
    Air Bags
    So my Colony Park came with a set of aftermarket air bags that went inside the rear springs. Whenever I had a large load I could air them up and keep it from saggin. My tailpipe fell off and burnt one of the bags. Anyone know where I can find a new set of these things. My local parts guy is out of ideas. I like the air bags instead of adjustable shocks because I can completely empty the bags and not upset the smooth ride from the stock setup.
    Jc Whitney
    http://www.jcwhitney.com/autoparts/P...003410/c-10101
    Some other Company
    http://www.globalintersection.com/au...&idRef=Froogle
      I want to run Edelbrock IAS Performers, but still wanted the air support, and can't afford a real air suspension... sounds like these would do the trick quite nicely! Any reviews?
        I've used them for as long as I've had the car. You keep the smooth ride of stock and can stiffen it up anytime you want. Better than air shocks I think, air shocks would make it feel like a truck.
          air bags
          "Anyone know where I can find a new set of these things. My local parts guy is out of ideas."
          Find a new parts guy.
          AIR LIFT makes a universal set for coil springs that fit right in. I have been using them for years. Have them in both the racecar and the ddriver. Co$t is in the $75 range and has not changed in several years. The air line can be hooked to a tee to fill both at the same time, or can be setup individual.
          "I like the air bags instead of adjustable shocks because I can completely empty the bags and not upset the smooth ride from the stock setup."
          Running them empty will destroy them quickly. They are designed to always have air in them. I think the min. is 10psi. That is what I run in the ddriver.
          Speed cost....how fast u wanna go??
          It's not how much hp u have...
          It's how much hp u can put to the track...
          Let's seperate the men from the boys and put that power to the track using street tires and stock suspension components
          'Tis infinately better to sit quietly and be thought a fool,
          than to speak and remove all doubt.
          I refuse to have a battle of wits with an unarmed person.
            I was debating replacing my rear coil spring / air shock arrangement with actual air springs from a later model Towncar with the associated compressor and wiring. I just haven't gotten around to doing it.
              Well, my parts guy is the local Autozone, there aren't any Napa's around here and the independent shops close at 4. So it's hard for me to get too. But, they say to keep pressure in the bags so they stay stiff and out of the way of the coil springs. The only thing you have to worry about is if the bags come off their seat but in my case when they were empty the bags didn't have enough room to move around. Also the rubber was such a thick and stiff construction that they couldn't get caught or pinched, they kept their shape. I think the company say's that to protect their ass and keep warrenty replacements down.
