Size difference between AOD and C4
    Right now im running my stock AOD driveshaft with my big bell C4. i have an aluminum driveshaft i want to put in. Is the C4 shorter than the AOD? The aluminum shaft is about 1" shorter than the steel and I want to have the shaft legnthened, i just need to know how much. The stock shaft looks too short with the C4 already.
    The Mustang C4 and AOD trannys were the same length.
      Right now it looks like i have about 4" of yoke hanging out of the tailshaft. Could i get away with extending the shaft say 2"?
        You'd have to push the yoke in and see how far it goes...
        '85 2-Door Crown Victoria
        302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
        '04 Crown Victoria LX Sport, '02 Jeep Liberty
        '83 Suzuki GS 1100E Motorcycle[/color]
          I read somewhere that the driveshafts are different, and you need to run parts off the other to make it work...
            I have an aluminum FRPP Mustang driveshaft. The driveshaft and yoke work with T-5, AOD, C-4, SROD... The yokes are 100% dimensionally identical between it and my CV AOD aluminum factory driveshaft.
              For about the 5th time I know what i need to use to make the driveshaft work. I just needed to know the difference in legnth.
