I could really use some help trying to figure out what’s going on. A month ago I had what I thought was torque chatter. It happened so fast by the time I got off the gas it was gone. I read what I could and waited for it to happen again. I also checked fuel pressure and it was 30psi. Fast forward to today. It stalled in a slow left turn in the neighborhood. I didn’t realize it but the yellow check engine light was lit. I pulled over and it started right up. I turned the A/C on and got about a block when it acted up again. It wouldn’t take the gas pedal. Almost felt like I was driving into a severe headwind. I turned off the A/C, came off the gas and it cleared up. 10 minutes later it happened again. Wouldn’t respond well to giving it gas. It did act normal when I came off the gas. I drove it around for another 15 minutes and it acted fine. I initially thought fuel pump but the more I read the more I couldn’t exclude the crank position sensor. I have no idea how to proceed. Anyone have a similar issue? My wife uses the car often and I do t want her to have trouble on the road.
Thanks
Thanks
