Leaky 97
    Leaky 97
    I have a driver side leak whenever it rains and it gets underneath my carpet and underneath the carpet in the rear driver side also I cleaned out the cowl and I sealed up around the hood release cable where some people were getting leaks and I still got a leak after a rainstorm yesterday does anybody have a similar problem or a solution to this frustrating leak that I'm having thank you
    best suggestion I can make is lay a hose on the roof and let it run down the windshield while you watch under the dash for the leak.
      Do like Gadget 73 mentioned yet have someone spray the suspect areas with a hose while your inside checking for leaks with a flashlight.
      2007 Ford Crown Victoria LX Sport
