Maybe as a stop-gap i'd plug it, but wouldn't drive it around long. Cracked tires are sketchy as fuck. We wrapped a mustang around a handful of poles about 15 years ago because of shit like that. Poles are still there knocked over, i'll snap a picture of it one of these days.
Nail in my tire.
Originally posted by 87gtVIC View PostI'd plug it without hesitation.
Pick up a plug kit and over inflate the tire. Pull the nail out and jam the plug in there after reaming the hole out a little bit with the provided rasp. refill tire to normal pressure.
I would agree with going easy on it until you replace it.
Is there a date code on the tires? Maybe they were sitting on a shelf for a long time.
Not at all. You will need to pull it out.~David~
I have never seen a nail fly out. I suspect that the pressure in the tire from hitting a bump at speed would have blown that thing out long ago if it was going to go without a fight. You need to grab them with pliers and pull the suckers out. I have un-screwed screws though.
Don't need much extra air in the tire. Typically after you have done a couple of plugs you don't really need extra air at all. The first one you might try and be gentle, not so much after you get the hang of it. Pull it, ream it, plug it, pull out your tool. Should take maybe 30 seconds or so after you pull the nail. You prepare the plug for insertion prior to pulling the nail.
Some plugs require glue some specifically say use no glue. For instance Blackjack brand. Do they still sell plugs you have to burn first? Have not seen those since I was a kid.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
The plug will work as long as it makes a good seal. With as small of a hole as you have, fix-a-flat (or some other brand of tire sealer) will work fine.
I wouldn't bother with the liquid goo that you put in through the valve stem, except maybe in cases where you're in the middle of nowhere and can't do a plug right away. While even a plug without the internal patch is only intended to be temporary, at least you can count on it for awhile. I wouldn't trust the liquid goo for nearly as long. And the tire techs don't like dealing with that stuff when they change the tire.
As for the angle, you're going to be reaming the hole bigger for the plug anyway, so that should help straighten the hole at least somewhat (though I doubt it would matter).
Personally, I wouldn't want to use the plugs without rubber cement unless I really had to. I just feel better knowing there's some surface goo that's going to dry up and seal nicely.
Originally posted by DerekTheGreat View PostReally Alex? Thought you knew better..
You got to judge your own tires when it comes down to it. You are not comfortable with it, don't use them. I am comfortable with it, and will run it.
Alex.
Coworker ran with a plug in the sidewall of his chrysler 300 for YEARS. No issues. Nothing I would ever do but on the bottom of the tires I would never hesitate.~David~
