I was pretty sure I wrote a thread on this, but couldn't find it.
My issue is I hear a whistling sound that seems to be coming from the top/rear of the engine. It seems to be coming around the upper intake/IAC area. It is incredibly hard to narrow a sound coming from the engine, but that is the best I could do.
It goes away when you give it throttle, but comes right back when you back of of it.
((((UPDATE))))
So, I had used a propane torch "torch" and turned the gas on and went around the "area of concern" to see if the idle changed, no dice.
It sounds like its coming from the upper intake right by the throttle body.
I mean, it's consistent with the IAC, I guess
One thing I noticed one two occasions, when I first start it in the morning, it doesn't make the sound, but within a few minutes of running, BAM! it does it.
It's driving me nuts!!
I will try the carb cleaner trick (consistent with the propane thing I was doing) and take off the alt belt
((((UPDATE))))
