1998 Mercury Grand Marquis
So I was changing my intake manifold because there was a massive crack around the thermostat housing. After finally getting that last damn bolt loose from under the crash bracket (crash bracket was actually cut in half) and we were sliding it forward. Got it out and were counting how many bolts we had and somewhere between the sliding it out and setting it on the bench we lost that last bolt.
My immediate fear is that it fell into one of the open port heads. We stuck a magnetic rod down all of them, and put a shop vac to them, but nothing came out. A search of the ground and various nooks and crannies in the engine bay hasnt revealed it.
Basically my question is could one of them actually get past the rods around the bend and into the chamber. They aren't tiny (10mm 4inch-ish). I don't have a boroscope so I cant confirm there isn't anything deep down. I dont want to reassemble it, turn it over and kill it dead.
I have a shop vac, compressed air, various grabbers, and am probably being paranoid but better safe than sorry.
