2003 Grand Marquis Radio ?
    Originally posted by Vettecor View Post
    ... I was thinking about getting another "generic" radio or possibly another factory radio to see if that works.
    I hate to buy another radio if the antenna is the problem. ...
    You might be able to get a cheap factory radio for testing purposes at a junkyard. If by "generic" you mean any old aftermarket radio, you would need a wiring harness adapter if you don't want to be cutting off the factory connector.
      You could rig an antenna and plug it into the unit, see if it picks anything up.
      Pete
        I have installed 3 aftermarket radios in the last 10 years. My T-bird and Mustang have aftermarket radios. I have bought these radios from Crutchfield and NEVER had a problem.
        Today I also turned on the rear window defogger and the radio at the same time. No change, still nothing but static. No pitch change or volume change.
          Maybe I missed this but....
          Have you pulled the radio out of the dash to see it the antenna is even plugged in?
          Also, on some cars I've seen a radio antenna plug right behind the glove box, sort of a factory splice.
          And I've seen these get unplugged for different reasons.
            I just got back in town. Will pull the radio out this weekend. My love muffin, (wife), went out and bought some more CD's so she doesn't care if the radio gets fixed or not.
            I still enjoy listening to the radio at times so I am hoping I can find the problem.
              I pulled the radio out and the antenna is connected. I disconnected it and put it back on, still NOTHING. I checked under the dashboard, pulled the kick panel, and climbed in the trunk.
              I don't see any wires disconnected anywhere and I can't find the stupid module. I guess I will just play CD's.
              What makes me real mad is I got rid of 300+ cassette tapes last year. The car also has a cassette player. Oh well, s?it happens.
              I will try to get an external antenna just to see if the radio works with it connected.
