So I upgraded from a 95 Grand Marquis to a 2003 Lincoln Town Car. What a beauty! But I need tires. Right now I have 225x60x17 on there. What other sizes can I put on 17" rims?
What size of tires on 17" rims?
1995 Lincoln Town Car Executive Series: "Albert" my daily driver
1988 Lincoln Town Car Signature Series: "Don Vito Corleone" my Summer Cruise
2004 Grand Marquis LS: "The Boss" with floor shifter (loved it) - R.I.P.
1997 Crown Victoria: "Victoria, the Armadillo" R.I.P.
2003 Lincoln Town Car: "Nikkatello" - R.I.P. (Miss you the most)
1995 Grand Marquis: "Gustavo Gonzales, the dirty Mexican" - R.I.P.Tags: None
I'm assuming you want to go wider?
235/60/17
245/55/17
235/55/17
Those are probably your common (good selection of tire models) sizes that are a bit bigger but will still fit reasonably on stock wheels. Going too wide compromises handling and wear. Going too tall throws off the speedometer/odometer and causes rubbing while turning.
Thanks alot. I just wanted to know what sizes are the best options on those rims. And also availability.1995 Lincoln Town Car Executive Series: "Albert" my daily driver
235/55/17 is pretty inexpensive......muskrat gt size
