Here is a general repair procedure method that DIY’ers might find helpful for complex repairs. I developed this method after the heater core went on my 2000 Grand Marquis LS in May 2011. I knew this was going to be a fairly complex repair, so I just connected the heater hoses together with an elbow connector and hose clamps and spent lots of time doing research before tackling this job in the fall.
I started with Haynes and Chilton’s manuals and created my own checklist. I then found what I could on the internet and added anything new to my checklist. Before actually working on my own car, I spent a day at a U-pull-it yard and practiced on one of theirs. The one thing I learned from practicing that I hadn’t learned anywhere else is that Ford puts retainer washers on the plenum bolts on the engine side of the firewall during assembly to hold the plenum in place before putting the nuts on. It took me awhile to figure out why the plenum wasn’t coming out after taking the nuts off.
When it came to working on my own car, I used my own checklist and also had a pile of scrap paper for organizing all the fasteners and other small parts. When I took off fasteners/small parts, I wrote a number on my checklist, wrote the same number and a description on a scrap piece of paper, wrapped the fasteners/small parts in the paper, and placed the package in a fastener/small parts box. When re-installing, everything ended up where it was supposed to be.
This method also worked great for my intake manifold replacement in May 2012, though I hadn’t bothered practicing at the U-pull-it yard.
