Did it show up in the "feel" of the engine? Mine has "pep" and runs real smooth.
Poor MPG's
A bit. It wouldnt hurt to check.
03 Mercury Marauder- 63k
Will double check but tires were off, recently, pads and rest looked good!
The type of driving might make a big difference in fuel mileage. For example, of course, more idling time (like waiting at long traffic lights) will decrease mileage along with stop and go traffic. Also, higher ambient temperatures can sometimes negatively affect fuel mileage. And, slower speeds will result in lower mileage. Theoretically, fuel mileage increases with speed up until about 55mph or so.
Yeah, most if not all = city driving with all the negatives you mentioned. Still seems low to me but maybe that's all I am going to get!
Not sure - don't drive on the highways - maybe I should!
if you haven't driven it on the highway in a good long time... you may need to take a drive some weekend with OD off to blow the carbon buildup out (Italian tune up).
Are you running 5w-30 oil?2004 Mercury Grand Marquis LS
185 degree stat. 21mm rear swaybar with moog end links, Moog progressive rear springs.
JLT intake, B&M transmission pan, 2.25 inch duals, magnaflows, Powerstop drilled/slotted front rotors and ceramic pads. Kenwood Excelon deck, Kenwood 6x8 3-ways all the way around.
5W 30 Mobil1.
Originally posted by slymer View Postif you haven't driven it on the highway in a good long time... you may need to take a drive some weekend with OD off to blow the carbon buildup out (Italian tune up).
Originally posted by way2old View PostThe digital readout on the dash is just an estimation...
Granted, that's a sample size of exactly 3 cars, but still.... I figured with all of them behaving nicely, that those digital fuel economy readers were pretty accurate.
As long, of course, as you remember to reset the darn thing each time you fill up the tank.....1987 Ford LTD Crown Victoria 2-door Coupe - perpetually "sort of" for sale...
Black with Red cloth (velour?) interior.
Purchased on 10/10/2008, with only 70,386 original miles, and only ONE previous owner.
Reader's Ride post, First pic with "new" rims, Other pics with "new" rims
Originally posted by turbo2256b View PostDid you put bigger diameter tires on it than came from the factory?
Its the tire diameter not the wheel diameter that can effect milage readings even same spec tires from different MFGs can be different. Bigger dia slowes the speedo down larger speeds it up changes milage readings. Anothe issue is your rear gears. 2.73 in the city will get less milage city better highway. Gears like 3.55 more city less highway as a rule of thumb.Scars are tatoos of the fearless
