Digital Coolant Gauge Sensor Part Number
    Anyone have a Motorcraft part number for the coolant sensor that feeds a digital gauge for a 1995 Mercury Grand Marquis? I know there are TWO sensors, one right near the thermostat and the other on the intake on the passenger side. The digital cluster is not reading above one bar for the temp so I think we need the one on the passenger side?
    The one next to the thermostat (driver side) should be the one for the cluster. The one on the other side should be the ECT for the PCM.
    I know the one for the analog clusters (one wire) is the same one for an early 80s bronco (had to replace the one on my 93. Not sure what the digital clusters use though. If it does use the same part, that should be SW2328. Resistance range is around 75 ohm cold and 10 ohm at operating temp. Everything I'm finding says the digital uses the same temp sender (or the sender for the digital cluster isn't available).
      That's interesting as I thought the one, on the passenger side, was for the gauge and the one near the thermostat was for the ECM. I don't remember either one being a "one wire" connector - both being dual prong. Will have to take another peek. Probably best idea is to pull the one near the thermostat and see if luckily there is a Ford part number etched on it.
