Have a friend that "may" need to replace this sensor (haven't seen it yet so don't know for sure). It DOES have a Digital Cluster and I seem to remember there is one part for an Analog and one for the Digital Cluster (could be wrong here and there is only one). The Motortcraft Part Number is SW-2220. Is that the correct part for a Digital Cluster?
!995 Mercury Grand Marquis Oil Pressure Sensor
I can try to verify this when I get home and can look at my 93/94 manuals. Looks like the part is the same 85-95 from looking at parts listings. There's 3 different senders/switches. One for just a light (switch), one for a gauge (sender), and one for the digital cluster. This is from aftermarket listings though.
Originally posted by sly View PostI can try to verify this when I get home and can look at my 93/94 manuals. Looks like the part is the same 85-95 from looking at parts listings. There's 3 different senders/switches. One for just a light (switch), one for a gauge (sender), and one for the digital cluster. This is from aftermarket listings though.Last edited by friskyfrankie; 12-17-2024, 01:35 PM.What I Own: 1993 Mercury Grand Marquis GS
Looks like the digital cluster uses the "with light" sensor. Normally closed and opens with pressure to turn the light off. This is the same for a cluster with an idiot light and the digital cluster. The ones with the idiot gauge are normally open so with pressure they close to pull the needle up to the midpoint and open with no pressure to cause the needle to drop to the floor. Unfortunately, I don't have a part number.
