I flushed and filled the cooling systems in the Escape & TC 5yrs ago using Prestone 5 yr coolant and distilled water The miles I accumulated on each vehicle is pretty low. I can see the color of the coolant is not as vibrant as it was when I first changed it but it is still clean.
I am not anxious to find the necessary time to do another flush and fill.
So I am being tempted by the siren song of 4-way test strips. Of course I would use the refractometer as well.
According to the interweb 4 way strips test for Nitrite, Molybdate, Glycol and pH.
I Could also test coolant < .3-.4 volts at a fast idle. But I don't know if this is redundant given the strips and meter.
So are these reasonable methods to go for "extended" coolant life?
Or what should we all know here?
