Nice. The underseat lights were something I really liked added to my CV so much so that I also added it to my ford Escort too. It was just nice to have.
91 Cartier Memory Seats
I've finaly continued this project.
I used a M10 1.50 70mm bolt, 1.5" height spacers, and a 0.5" drill to mount the elevated corner of the 91 seat to the 88 floor.
I did fully wire up the memory seat module and connect to the memory seat switches. Pressing set button turns on the green light. However there's something broken as the module isn't moving the seat automatically. Granted I dragged and bounced the module around getting it back from the junkyard, so it may be broken. The seat motors also look to have been replaced at some point by the previous owner so perhaps they are incompatible with the memory module. I'm likely going to delete the memory module since I don't really need it, I don't want to spring $90 for a NOS that may not even solve the problem, and I don't even have it secured to the floor. Even though I got it all wired up so nicely.
91 driver seat mounts the seat belt electrical connector on the seat frame - I didn't use this and put my original belt receiver in. I don't even know what the car does with this detection. The belt light on the dash seems to turn on and off by itself in any case.
91 driver seat also has a pressure sensor under the cushion I imagine has to do with SRS. My 91 pass- seat didn't have this, I presume because it didn't have pass- SRS. I wonder what fun things I can do with this sensor.
