topic says it. Need a good high res shot of the back of a 01 police cluster to verify the circuit I'm using to get the temp gauge working.
The original gauge sensor in the 93 is ~37ohm at 170 degrees while the ECT reads about 3.7K ohm. If the back of the Police cluster is the same as the civi cluster (which I don't think it is) this may be my issue. I specifically need the temp gauge area.
right now the gauge reads almost H at normal operating temp on the original sensor and well below C (like an open circuit and I know it's not because I've tested it) on the ECT. Also, if someone has the EVTM of the POLICE cluster that would be nice too.
