High Side Fitting For 95 GM
    Need the "High Side fitting" that screws into the high side line. That would be the high side "test port". Anybody know if they are available WITHOUT buying the entire line from Ford? Places like Autozone, etc have them or do I need to be looking at JY's. Think this is an item I would prefer new!!
    Normally AC fitting are available at the better flaps.
      Could it just be the schrader?
        Could be as I didn't have time to check it. Have to see if it is a schrader or ball valve and take it from there.
          murray part#59972
            Thanks for the part number!! Got to see if it is just a loose valve core (if schrader) or needs to be replaced. Got a few fittings here but will take a few days to get to and see if I already have a replacement. Bobby
