Need the "High Side fitting" that screws into the high side line. That would be the high side "test port". Anybody know if they are available WITHOUT buying the entire line from Ford? Places like Autozone, etc have them or do I need to be looking at JY's. Think this is an item I would prefer new!!
High Side Fitting For 95 GM
"Cars are for driving - PERIOD! I DON'T TEXT, TWEET OR TWERK!!!!"Tags: None
Normally AC fitting are available at the better flaps.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Could it just be the schrader?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostCould it just be the schrader?
Thanks for the part number!! Got to see if it is just a loose valve core (if schrader) or needs to be replaced. Got a few fittings here but will take a few days to get to and see if I already have a replacement. Bobby
