That should make it easy. Looks like I can just tie the little wire at the starter solenoid on the 92 into the same wire on the 91 harness to backfeed the TFI module for start ignition power. Theres possibly some cleaner way to do it, but I'm looking to make this as minimally invasive as I possibly can .
