Replaced the Air Bag Module a month ago after getting a Code 52. Was good until today when I started receiving a Code 24. Internet is chock full of info but none of it is making any sense to me. Where is the place to look to offer a fix and how is it done? Seems to be a possible short or loose connector but where is "the rub"! Thoughts????
1993 Mercury Grand Marquis Air Bag Code 24
The safing sensor is behind the driver side kick panel... behind the bracket of wire harnesses... behind the inner sheet metal inside the large hole there that all that wire is in front of IIRC. There's a 4-pin harness that goes to that one. When I started having issues with my airbag system, that's where it started. Never did find that one on my car either and then it went to code 51 all the damn time. If I can remember to when I get home, I'll get the airbag safing circuit diagram out for you.
- Likes 1
Originally posted by sly View PostThe safing sensor is behind the driver side kick panel... behind the bracket of wire harnesses... behind the inner sheet metal inside the large hole there that all that wire is in front of IIRC. There's a 4-pin harness that goes to that one. When I started having issues with my airbag system, that's where it started. Never did find that one on my car either and then it went to code 51 all the damn time. If I can remember to when I get home, I'll get the airbag safing circuit diagram out for you.Last edited by friskyfrankie; 05-25-2023, 10:40 AM.What I Own: 1993 Mercury Grand Marquis GS
Typically the connector needs to be disconnected and the female ends squeezed a tiny bit with some needle nose.
- Likes 1
You probably just have to unbolt the harness. It is quite a mess of wires in there. May have to unbolt a few to get at that one.
I do suggest to disconnect the battery and then hit the brakes to discharge the airbag module before messing with the system, just in case.
Wiring diagram: http://grandmarq.net/sly/1993%20MGM%20Airbag.pdf
Location (bottom left of diagram): http://grandmarq.net/sly/1993%20MGM%...g%20Sensor.pdf
- Likes 1
Originally posted by sly View PostYou probably just have to unbolt the harness. It is quite a mess of wires in there. May have to unbolt a few to get at that one.
Location (bottom left of diagram): http://grandmarq.net/sly/1993%20MGM%...g%20Sensor.pdfWhat I Own: 1993 Mercury Grand Marquis GS
After looking at the diagram, it may be a 5-wire in a 6-wire harness. Not at all sure about it, but it will be the smallest connector in that batch as the others are body harnesses and have a LOT of wires in them.
- Likes 1
Originally posted by sly View PostAfter looking at the diagram, it may be a 5-wire in a 6-wire harness. Not at all sure about it, but it will be the smallest connector in that batch as the others are body harnesses and have a LOT of wires in them.What I Own: 1993 Mercury Grand Marquis GS
Contact cleaner maybe. Since they're inside the vehicle, dielectric grease typically isn't needed unless it's prone to leaks.
- Likes 1
Would have used the contact cleaner as well but I guess I am spoiled by usually also using dielectric grease after the cleaner dries. As you indicate, though, probably overkill. Hopefully, I can get to it soon but for now, have "bigger fish to fry"! As long as it doesn't damage the module it can wait.What I Own: 1993 Mercury Grand Marquis GS
Today's Update: Got a chance, in between doctor appointments, to devote some time to this issue. Pulled the kick panel, found the sensor (light blue and the proper color and number of wires according to Sly's diagram). Disconnected it and sprayed both sides with contact cleaner spray. Connectors and pins all were intact and clean. Reinstalled and still received a Code of "24". Just for grins, pulled the connector and started the car. Now I had a code of 21 (just to prove I had the right connector). Put it all back and now getting the original code "24". I was reading there is a connector, behind the glove box, that needs to be "shorter out" to clear a code of "21" but wonder if this needs to be done to clear any code from the module? If so, I'll need to find it and try the procedure. I assume it is a different connector from the one used to program key fobs? Also, will the air bag system still work correctly with fault codes or is the system non functional until no codes remain?" Thoughts????What I Own: 1993 Mercury Grand Marquis GS
Still can't find a definitive answer as to what the problem is! Back of the sensor is very tight to get to so checking voltage in and out would not be easy. Wonder if the problem is coming from elsewhere and this is a "ghost code" like Microsoft does with many Windows codes?What I Own: 1993 Mercury Grand Marquis GS
You may need to remove the sensor from the side and verify the mounting point isn't oxidized. It may be sensing high resistance to ground. The resistor in the sensor may also have drifted enough to throw things off. Doubtful, but it is possible. The module rechecks everything at each startup, so codes should disappear when the issue is resolved.
Originally posted by sly View PostYou may need to remove the sensor from the side and verify the mounting point isn't oxidized. It may be sensing high resistance to ground. The resistor in the sensor may also have drifted enough to throw things off. Doubtful, but it is possible. The module rechecks everything at each startup, so codes should disappear when the issue is resolved.What I Own: 1993 Mercury Grand Marquis GS
