With the B&M drain plug I drained fluid and added 3 qts 21 oz and now I need to suck out a little as it is just over the max when hot on an 80 degree day.
IIRC it is a bit more with the U-Haul pan on the Marauder.
08 TC Transmission drain Pan How much oil?
When I've done the suction method using the fill tube in my 2000 MGM, I've gotten about a gallon with some left in the pan. You should be good with 5-6 quarts if everything is the same on your 08.
Leave a comment:
Hi,
I changed the filter and put in a B&M drain plug last year so I can drain and replace some fluid each year. I have the info on how much fluid I need to buy but it is not nearby.
It should be about the same as a pan drop amount.
Before I go to the store, anybody remember how much fluid is needed if you drop the pan?
JayTags: None
Leave a comment:
