Have seen specs of 8-28 ft pounds which is a PRETTY big range!
Transmission shudder
Plug: tighten so it can't leak, but not enough to strip it outSummer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Whenever I do anything that might require me to look something up, I get both the Haynes and Chilton's manuals from the public library. I don't have them handy now, but the following Autozone page indicates 21-23 ft-lbs around the middle of the page, item 2 under "To install" (though I'm not saying that is indeed the right number):
FWIW, when I did mine, I tightened it without a torque wrench to a depth that I was comfortable with, and it went a lot deeper when I did it to the right torque with a torque wrench. For me, this is one of those things that you want to use a proper torque wrench on.
Well guys. Thanks for all your help.
I changed the fluid, took about 11-12 quarts (oddly enough)
Shudder is gone!
You guys are the best!"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
I tightened the pan down to 80 inch lbs first, then 120 inch lbs
TC plug 20 ft lbs"To Find yourself, you must first lose yourself"
no, didn't have to ad lubegaurd, just 12 quarts of mercon V Castrol Transmax"To Find yourself, you must first lose yourself"
There should already be enough friction modifiers in Mercon V so no need for Lubeguard.
Originally posted by miamibob View PostThere should already be enough friction modifiers in Mercon V so no need for Lubeguard.
The Lubeguard basically converts Mercon/Dexron III into Mercon V. Or it replenishes modifiers in fluid that probably should be changed anyway. Fresh fluid of the right type fixes the problem.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostThe Lubeguard basically converts Mercon/Dexron III into Mercon V. Or it replenishes modifiers in fluid that probably should be changed anyway. Fresh fluid of the right type fixes the problem.
I was very fortunate but nonetheless glad I did this, I am plenty happy with the shifting. And many thanks to you guys for your endless help!"To Find yourself, you must first lose yourself"
