Early/sloppy shifts
    Thank you ever so much for the explaination. Helped me understand it completely
      Has someone changed the gears? If the gears were swapped out the computer will still be using the original shift points based on the original gear set unless the computer is reflashed. Mine did, it shifted at about 6mph into 2nd unless I gave it more gas until I installed my tune with the xcal 2 from Lonnie.
      Silver Frost 02 Grand Marquis GS, 3.73 Trac-Loc,
      Dual Exhaust w/ FRPP Megs, MM Airbox & 80mm MAF, SCT XCallibrator 2 from BOC,CVPI Rear Facia,
      Pro Guard, Edelbrock IAS Shocks,Addco Sway bars
