Yup. Mine is so low it'll be on the bump stops in the morning and the air compressor only picks it up about an inch. I didn't adjust it that way, but I like it!
I did it today to the LSE. It got an extra 1 1/2" higher them before. There is a little problem though. The drivers side it perfect for the stance with the stock tires. It sits at exactly 29" in the drivers side. The passenger side is almost an inch higher. It looks like it needs bigger tires on that side. On my vic there is a 1/2 inch difference per side but not an inch. What would cause that? I may lower it back down alittle if I can't figure out why that one side is so much higher. Any suggestions cause the merc has never been in a wreck so the frame can't be tweeked.
my '85 has about 1 3/4" difference in height in the rear. Swapping the springs doesnot change it. It might be the way the weight is distributed in the car.
Got back in from do this. I put the slider thing in between the stock and the max height. Perfect amount now. The drivers side is 28 1/2" and the passenger side is 29" so it is perfect now. I will be sure to take pics of it when it gets nice enough to wash it again.
