To trac loc or not
    To trac loc or not
    Ok guys are the ford trac loc good or would an after market eaton or detroit be better....I keep being told that the ford trac loc sucks...I can pick one up cheaper than the eaton or detroit...I want to do this once ....not twice...
    President He Man Woman Haters Club
    Life should not be a journey to the grave with the intention of arriving safely in a pretty & well preserved body,But rather skid in broadside,Thourghly used up totaly worn out & loudly proclaiming...WOW WHAT A RIDE!!!
    http://www.myspace.com/dabearsplace
    eaton is basically the same as the stocker. Torsens are great but cost more than my car...detroit is clunky and loud. The true tracs might be alright. No experience with them.
      i have a 2.71 trac lock in my white '87. i have had no problems w/ it except when a friend borrowed it and got a flat. they had a diff tire size put on and it started acting up. i had a tire that matched the other side put on and no more problems. i have changed the diff. oil twice and all the teeth look great. i live on a gravel road and fight some good snows w/ the car and it hasnt let me down.
      Addicted to 86-87 Panthers
        Yeah, I have one of the TrueTracs that mrltd mentioned. They are maintainance free, top notch performance, no noise wat so ever, and does not creat any adverse driving characteristics. However, the down side is they are pretty expensive. A little bit over $400 for just the differential.
          Originally posted by 87_crown_vic
          "I have a 2.71 trac lock in my white '87...".
          Do you mean a 2.73 gearset?
          '90 Mercury Grand Marquis GS
          5.4L swap coming soon.
            from the code on the metal plate on the rearend it is a 2.71
              Whats the code? Not sure there was ever a 2.71, 2.73 was standard on many cars though.
                No 2.71 that I've ever heard of. Get the AX code on the door sticker.
                '95 Ford Bronco XL -
                sigpic :rebel:
                  Thanks guys I am getting a set of 410s and trac lock from Hwy cruiser I can not wait....
                    Ah, so YOU got em!
                    Aha! It's all good mang...
                      i was having fun wth my trac loc a few minutes ago, in a parking lot. ooohhh yea
                      grand_marquis_gt: "Wow dude, you got the GMGT sedan!"
                      there, now im cool too
                        You may want to look at replacing the clutch pack on the trac-lock. It's not 100% dead, but it's seen better days. Can anybody help him out on how difficult a job this would be?
                        Supercharged '03 Mercury Marauder - SOLD
                          If it is out of the axle it is not a big pain, just getting it in the diff while keeping all the friction and steels together is a little tricky.
                            Yep...I got a rebuild kit already setting here.I have a buddy who is going to rebuild the unit for me. Then I will install it one night after work..Zooom Zooommm
                              If you run 4.10's you'll probably need the extended tailshaft and driveshaft from a P71 or you might get serious vibration issues, ect at higher speeds. Safety concerns too. Panthers have very long driveshafts that tend to vibrate at higher speeds. Anything more than 3.55's usually requires it
                              Silver Frost 02 Grand Marquis GS, 3.73 Trac-Loc,
                              Dual Exhaust w/ FRPP Megs, MM Airbox & 80mm MAF, SCT XCallibrator 2 from BOC,CVPI Rear Facia,
                              Pro Guard, Edelbrock IAS Shocks,Addco Sway bars
