I need to make the tread width on a 1997 crown vic narrower. MY current tread width is front 62.8 I need to shrink that to 59. So that's roughly 3.8 or 3 3/4" total or 1 7/8 per side.
The rear is much worse. I need to go from 63.3 to 56.4. total of roughly 61/4 or 3 1/8 pe side.
Can I do this with changing the wheel backspacing?
I am thinking about swapping entire 97 crown vic. chassis under a 57 Ford fairlane 500 and the crown vic is slightly too wide setting the tires outside the 57 ford fenders. The wheelbase is off surprisingly the 57 ford is 118 and the CV 114.4
Any thoughts
appreciated
Thanks
Any thoughts
appreciated
Thanks
