My car somehow came with the P71, 700 lbs/in front springs. I restored the RAS with HD (stretch limo) rear air springs and there are Bilstein B6 shocks now all around (clocked 4000 mi on those), which are the firmer, sporty shocks.
The front P71 springs are too firm and that's jarring. I figured I would just drop in 540 lbs/in rated front coil springs and be done with it.
Being aware of the lift kit syndrome caused by aftermarket AC Delco and Moog springs claimed to be 'counterparts' of the stock HPP front springs, I bought Swedish-made Lesjofors front coil springs.
Well, that's a bummer, now the car sits at least 2" higher in the front and won't sag down anywhere close to the front ride height that the P71 springs the car came with provided. I replaced these because the P71 springs are too damn firm for my setup.
The Lesjofors compress and rebound PERFECTLY, but the front ride height is unacceptable, the car looks like a speeding motor boat and has been so for several days, even with speeding over potholes to make the damn coils 'wear in'.
OEM NOS HPP-grade front springs are unobtainium. Well, they do exist. At junkyards I got no access to (I do not live in the States) and on eBay, for insane money (240 for a pair plus 250 for shipping). Don't get me started on custom springs from Eaton or other makers, their prices for shipping to Europe are INSANE (Eaton said SIX HUNDRED BUCKS for stock rated, 1" drop front springs, and 2/3 of the price is shipping!).
I got these options:
(1) push the money envelope down the rabbit hole and get NOS OEM HPP springs SOMEHOW;
(2) try chopping one coil of the Lesjofors springs;
(3) get other springs, I heard Moog 5660 that fit G-Bodies and Chevy S10 trucks provide a good spring rate and may lower the front end 1" below the stock height.
I did consider the baking oven trick, but that's too nuclear and involves several risks (including death by forcibly ejected spring compressors...).
The worst case scenario is to suffer on with the P71 springs. Argh.
Now, the Lesjofors front springs (EW!) I got have 8 coils that I assume are active (the 1/2 of the 9th bottom coil has a closed and ground end). Hence:
OEM HPP front coil spring rate: 540 lbs/in, minus one coil, should see an increase by 67.5 lbs/in or so, up to 607-ish lbs/in. This would be nice and provide a good match for my Bilsteins, bc the P71 springs I had are rated at 700 lbs/in (and were too damn firm).
If I choose to go with the Moog 5660 (for G-bodies and S10 trucks), these are said to provide a nice 1" drop from the stock ride height. They are open-ended (infinite coil) springs tho; any recommendations for fitting them correctly on a 98-02 Panther?
If you guys got any alternative suggestions for front coil springs that drop the car 1" below the HPP stock ride height, I'm very much open to hear (read) from you.
