Upper Ball Joint Eccentric
    Does anyone know where to find some upper ball joint eccentric nuts for the 95-97 control arms?? I cant seem to find them anywhere.
    Also the bump stops for the upper arms....
    -Phil
    Universal bump stop replacements only. as for the eccentrics... junk yard. I haven't ever seen those included with the control arms or the ball joints unless you get them both as a complete assembly. If it's for the brake swap... the early aero arms should use the same ones.
      Thanks Sly. There are two closeout arms on rockauto that include the stops and nuts for $46 shipped. If I cant find any used ones I'll just spring for those
      -Phil
        you mean the actual cam, not the lock nut? I've never seen the cams for sale but Ford probably does have a part number. Probably obsolete / NLA or costs as much as a whole arm does though.
        Cams ought to be the same 92-02. The ball joints can interchange through that run at least.
