Thought I might change the axle bearings and seals on the 03. Would like to buy USA made bearings & seals but have no idea what brand(s) to look for these days. Any info? Otherwise is Koyo made in Japan?
Thanks,
Jay
03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice 02 SL500 Silver Arrow 08 TC Signature Limited, HID's Mods>06 Mustang Bullet Rims 235/55-17 Z rated BFG G-Force Comp-2 A/S Plus, Addco 1" rear Sway, Posi Carrier, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17 12 Escape Limited V6 AWD, 225/65R17 Vredestein Quatrac Pro, Winter 235/70-16 Conti Viking Contact7 Mods>Beamtech LED headlight bulbs, Husky floor liners
Maybe check out SKF. Not sure if they're still made here though. Hopefully the axle shafts aren't torn up like they are prone to do on the 03's. Been down that road 3 times on my 03 LX Sport.
About 35Km miles iirc. They looked good about 5k ago which surprised me a bit. Going to pull them to get to parking brake stuff so thought I would change bearings this time. Certainly seals.
