I was looking at replacing the puny rear sway bar on my Budget Beast... This is along with a complete suspension rebuild.
What's the diameter of my current front/rear sway bars? (I'd measure but I am out of state)
Can I get away with replacing only the rear, at least for for now if not permanently? I understand this depends on which sway bar I end up choosing, balance and so on.
Can I use a Marauder Rear Sway Bar? (The one that I heard on other forums may work depending on year, costs significantly less than the Addco 650. I believe the Addco is thicker than the Marauder's coming it at One Inch.)
Let me know if you have an answer for my q's or have even better suggestions for the upgrade OR ANY OTHER upgrades you can point me at. I will post a write up of my Marquis once the work begins. Thanks in advance!
