Front end suspension torque specs
This is a sticky topic.
    Long story short, I got the wrong service manual for my TC, (97), so I would like to know where I can find the troque specs for the front end suspension (upper/lower control arms, tie rod ends, stabilizer links, ball joint studs, shocks). Any info would be greatly appreciated
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
    Are you looking for specs for a 97 Tc? or the 89? You got the 97 book by mistake instead of the 89 or?
      No, I ordered a service manual for the 1997 TC, but I got a 97 CONTINENTAL, (the order was mixed up), so I need the data for a 1997 in the mean time till I order the right manual (well hopefully they get it right next time)
        This is all off the top of my head:
        ball joint nuts - 100-120 ft-lbs
        control arm nuts at the bushings - 100-120
        alignment bolts (hold the upper control arm rod to the frame) - 80 but I always use breaker bar tight - around 120 or so, but then my 88 has all the rough patch for the bolts to tack to kinda flattened.
        all the castle nuts so far that I've done were specced to 100
        sway bar links: locknuts (pinch or nylock) and should be obvious as the bushings squish down. Once they are compressed to the bar or control arm give another turn or so and you're done. They won't really torque down until you run out of threads or squish the hell out of the bushings.
          good n tight, approximately 1/2 turn before it breaks.
            Pinned - because it should be, and I don't want to have to keep searching for it every time
            '80 Town Coupé
              wow... was I right with all those numbers? That's just what I guessed at because I always just use breaker bars to tighten that stuff (except ball joints/tie rod ends - I get the torque stick for that).
                I don't know, but that's what I used for the UCA to shaft nuts. If I had whale shop manuals I'd check; I've only got an '80 manuals disc
                '80 Town Coupé
