Do you know how they work? This rear was already out. Both caliper hoses were dangling, no other lines on it. They have brackets but I cannot see where they attach
to the rear one has a distribution block, a "t" with a bracket on it.
They don't run on the rear at all. The hard line comes down the frame from the master cylinder and ends just about directly above the caliper on the driver's side. If you have a non-ABS car, the second line goes from the driver's side caliper hose with it's integral T across the frame above the fuel tank area to the wheel arch on the passenger side. The caliper hose runs from the hard line at that point. Not sure exactly how they hook the hose to the frame, whether its a threaded hole or what but on my car there is a 1/4" bolt welded to the frame and a nut to retain the hoses.
