On my 1994 MGM, I have noticed that SOMETIMES if I make a very hard left turn (close too the end of the steering wheel's range) I will hear a very harsh "CLUNK" noise. It has no happened when I turn right. I'm thinking ball joints? Anyone have similar symptoms? Is it an easy/cheap fix?
Mechanical/clunking noise on hard left turn?...Sometimes.
It looks like your answer might be in the following thread, which has a handy photo to boot:
Discussions related to the Aero/Whale specific drivetrain components. Steering, brakes, suspension, transmission.
It's quite common for such noises to occur if the steering stop contact points are not greased. If that doesn't work, then it's time to start worrying.
