Rear Pads Phenolic vs Steel?
    Edit: Front Pads.
    Is there a difference between the pads for phenolic police calipers and civilian caliper pads? Can they interchange? Rock auto specifies their pads phenolic or steel, but these weren't specified. Will these fit a police caliper? Centric 30007480. http://www.rockauto.com/dbphp/prt,142,30007480
    87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
    Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,
    The clips on the pads are different, since the caliper piston bore is different.
      yep. performance difference is minimal at best, but cop pads don't fit on civi calipers or vice versa.
        marquisman is right.
        You can not use phelonic pads in the civi caliper. You would have to swap to the phelonic calipers for that.
        I've seen both police and civi cars with either type installed as original equipment.
        But more CVPI's had phelonic than didn't.
          So how do you tell if you've got phenolic or steel?
            take it apart
              Originally posted by Lincolnmania View Post
              take it apart
              You take the pads off, and the piston side pad will have three "fingers" on the back which hold it in the piston.
              These "fingers" will either be large or small depending on the pistons you have.
              Then just take the pads down to the local parts store and get them to pull a set of pads and match them up.
              And that will tell you if you have phelonic or not. The difference is obvious when you have the two styles side by side.
                small hole = phenolic, large hole = steel. The presence or lack of rust inside the hole is also a tell. The phenolic is black plastic, so it can't rust. Steel is, well, steel.
