why is the official tow rating so darn low?
    2009 mercury grand marquis here. I've never been able to find out why a car once rated for towing 5,000 lbs is now rated at towing a measly 1,500 lbs when I have four wheel disc brakes, air suspension, a transmission cooler and a full frame underneath it. Searches haven't yielded a definitive answer other than some people blaming the "watt's linkage" setup. I'd like to think its the grand SUV/truck sales conspiracy/myth machine at work. Any insight is welcome.
    To try and sell you a pickup truck. Thats really it. These did not get any weaker than they were in the 80s, and are in fact much better suited due to the more powerful engine and better brakes. I've towed 5,000 lbs with stock 80s brakes, and its goddamn scary. In truth, 5,000 with the upgraded brakes is still sort of scary, so perhaps part of the de-rated tow figures is a safety measure.
      you really need upgraded brakes, load lever shocks or air springs, and good tires. my grandpa's 87 MGM company car had the tow package and some kind of load lifter air shocks in the rear with normal springs. It also had both anti-sway bars. I never saw under the hood, so I can't say if it was 5.0 or 5.8, but it never lagged on the 2 ton float it would tow at Christmas time in the town parade. And with all towing, you have to know your brakes and compensate for the added weight. One thing is for sure... the cars don't like much tongue weight at all. 500 tops unless you have helpers.
