01' Town Car transmission slipping
    when i'm cruisin between 40&55 and go up a small incline, or flat surface even, the transmission slips, like it cant decide to go to 3rd or O/D. its the 4R70W. i know someone posted about this before but he had the check engine light on, i dont. i plug in the code reader to see if anything comes up but nothing does. anyone have any idea what it could be? it used to do it every once in a while but it has gotten more frequent the past week
    2010 Toyota Camry "Traveller II "
    54,xxx miles. New daily driver
    2001 Lincoln Town Car Signature "Leroy"
    rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
    114k miles. Sold to my coworker.
    1998 Toyota Camry "Traveller"
    Dead and sold.
    Check fluid level? Is it only between 40 and 55? If you turn O/D off at those speeds, does it behave normally?
    2000 Mercury Grand Marquis GS HPP - SOLD
    Wore out the cam chain tensioners and jumped time at 176k miles.
      fluid level is where it should be and is clean. if i take o/d off it behaves just fine, its only when o/d is on. its only between 40 & 55 and if i'm holding steady, if i'm accelerating it has no problem
      Dead and sold.
        Sounds like maybe a line pressure issue. How long since your last fluid and filter change?
          not 100% sure on that, was done before i bought it from my dad, so probably a year and a half to 2 years ago
          Dead and sold.
            how many miles?
            drop pan look for clutch material and metal, change filter, fill up andadd a bottle of lubegaurd........might just br torque converter shudder
              probably 20k since the last time it was done, has 73k on her now.
              Dead and sold.
                Fluid and filter change help things any?
                  I'm seconding torque converter shudder, the 4.6s were known for having it, I have it in my '99. It's like a fast duhduhduhduhduh on upshift? around those speeds. Mechanic dumped a can of shudder quiet or whatever it is in, helped for awhile, getting worse now.
                    Have used a bottle of Ford Limited Slip Diff liquid in my '95 GM and so far (over a year) I no longer feel the shudder. May be worth a shot.....
                      tourqe converter
                        so if its the torque converter, what should i do? replace it? or is it something thats gonna happen even with a new one?
                        Dead and sold.
                          May want to try what I posted above!
                            thanks! ill try that whenever i rustle up the money, haha
                            Dead and sold.
                              do you mix it with the tranny fluid or just put it in by itself?
                              Dead and sold.
