Hey guys, I just ordered the lower ball joints for my '01 GM. I also ordered polyurethane control arm bushings but I am concerned with them squeaking, if not right after application, not far down the road. Which obviously I don't want. I want a smooth, quiet ride. I have been reading quite a bit today on non GM cars.
So my questions are:
Do polys wear faster than rubber?
Are the rubber ones pressed in rather than the polys that are not?
Is there a fool proof way (or almost) to ensure squeaking will not be an issue? I have read where some grease every side of everything. Inner shell, inner & outer bushing, inner & outer race. And some that adhere the bushing to the inner shell using a bonding agent stating the bushing should not move, but only the race & bolt within. There was also mention of scuffing the outer part of the bushing.
What type of grease works best for long term lubrication?
I can probably deal with a stiffer, more responsive ride that the polys will bring (GM is by far the most comfortable ride I have owned and my Mustang is lowered and very rigid)
I am trying to wrap my head around this and decide if I should cancel my poly order and get the rubber.
