Hi,
my 2003MGM has now 45000 miles. I encountered some shivering when applying the brakes, especially when braking down fom higher speeds (80/90mph). Seems to come from the front. Changed the front rotors and pads, inspected the brake pistons carefully, everything is fine.
Brake job helped, but after 2-3 days the shivering was back.
Put her on a brake test stand and she performed absolutely smooth. No shivering on the brake stand indicator needles.
It is all fine while driving, shivering appears only when pushing the brake.
Visually the rubbers on the front axle assembly still all look good.
Any idea where to start with this issue?
Thank you !
JoJo
Thank you !
JoJo
