well I have not gone through all posts to see if this problem has been addressed; but my situation appears different from others I have spoken to. First, I have a '94 GM, 210,000kms, and no problem with the air ride until now. After I had an air leak, the rear susepnsion went down all the way, I had to drive a short way to get home; but after the air lek was repaired the system works normally for about 1/2 hour, then the warning light comes on. No, the rear suspension does not drop, and I have been all over the vehicle above and below and I am certain to further air leaks remain. The rear air bags look good as does the sensor at the rear axle. Any ideas? Could damage to the sensor have occured when the rear suspension was so low and I was forced to drive it home?
1994 Grand Mrquis Air Suspension
The light normally comes on when the compressor runs an excessive number of times, or for too long to reach trim height. Its usually caused by a leak at either the drier or at the solenoid. If the rear doesn't sink overnight, the springs are probably fine but I'd be spraying some soapy water at the connection on the compressor, and at the solenoids where the air line connects. If its bubbling away, pull the leaky connection apart and replace the O rings inside.86 Lincoln Town Car (Galactica).
