I'm of the understanding that an individual or two may have done this... I'm curious how you got the tap to cut a thread. Am I just being a pussy and need to drill deeper, or did you cut the tap so the threads start less shallow? I'm a little worried, as I bought a new housing to avoid the problems associated with R&R of the bushing. Any thoughts?
Force lube w/o bushing removal
There is no requirement to do it with 3.73's unless maybe your a circle track racer, or like to do a lot of top speed runs... I only did it because my car will be seeing a LOT of highway miles next year (10hr trip between school and home, if this transfer happens).
That said, if you want to do it, its not difficult at all, you needn't even remove the bushing to get it done
I do quite a bit of highway driving, though not as much as you wil be. So far so good.
you needn't even remove the bushing to get it done-Michael
