I plan on deleting the 2nd set of cats. probably have local exhaust shop do it. funny thing is I don't think they put my rear 02's back on after they installed new rear cats.
correction. they put the o2s in before the after cats.
that can't be the rear cats... all panther exhausts have the rear cats level and then the pre cats are at the fucky angle/.
right!!
and even at that funky angle, if you take them off the car, you should still be able to get at them! Just try using a piece of rebarr or something narrow long and strong to get at the pre-cats
That pic is of the rear cat. The part that has the bend is after the rear cats. I know for a fact I cannot get a straight piece of rod in it to break it up. The fronts are not bad at all on mine.
Im tellin ya, you can get at them for sure. You take em off, break the front one up from the front and the back one up from the back. You get at each cat from their respective closest opening.
Even soaking it in PB Blaster for a couple of days before hand didn't work? I don't have access to a torch.
Do you know a mechanic who's not uptight about these things?
If so, then I recommend visiting his shop. Pay the couple of extra bucks to have your mechanic remove the cats so you can then gut them....'tis what I did!
