I don't know if this is the right place to post this so mods, please move it if necessary. I put 22" rims on Mz Perl (2005 Grand Marquis) and every now and again, I get rubbing on the front passenger or driver's side depending on what I'm doing (hitting a bump or taking a corner/curve too fast). I'm looking to lift the body 1-1½" and was told that spring spacers or longer Springs would be the way to go. I don't know what Springs to get and can't, FOR THE LIFE OF ME, find spring spacers for her! Do you guys have any suggestions or advice? Btw... I don't have a sh!t ton of $$$. Thanks for looking.
Body lift
2003 should be the same setup as 2005. There's listing for 1.5 rear, but only 1" up front. I think due to the nature of the beast, being the coil-overs up front, you may be limited to what can actually be put there without having to modify stuff. If you're only just rubbing occasionally though, 1 inch should be plenty.
I have no clue how to install them though.
Originally posted by mjohnsoniii View PostI actually checked those out but didn't think about the two being the same setup. How can I tell/find out if they have the same setup?1997 Lincoln Town Car Executive Series - Charlene
Saved from a tragic fate, planned mild restoration. Now with working heat, perfect for the cold winter!
I thought you were referring to these type of spacers:
