curious if id be wasting money to do the ford racing 8.8 master rebuild kit first? anyone know?
planning on getting 4.10 gears in my 2003 grand marquis
Master rebuild kit when the gears go in, makes total sense to replace all bearings and seals when you have it apart anyway so you don't have to go in again for awhile.
Sent while running from the cops using Tapatalk1989 Country Squire - Twilight Blue, 347 stroker
Only if you don't have a Trak-lok differential.
03 Mercury Marauder- 63k
Besides Bearings, races and seals, what is in the kit?
Why only if no posi?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Putting 4.10s in a open diff seems a bit wrong.
Originally posted by SVT98t View PostPutting 4.10s in a open diff seems a bit wrong.
Yes from the "what is the point" sense.
Yes do everything at the same time, bearings, seals, gears, posi carrier, (if it is not already posi) and axles on inspection.
If the car has posi you probably want new clutches in there.
It may be a good idea to open the rear, pull the axles and inspect them in advance of any new parts install project. This way you can have good axles on hand if they are needed. Unless you can lay up the car for several days when you are doing the rear. 2003 came with soft axles when new, so they may already be replaced by now if not, they probably are shot.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Convert to 31 spline axles, get a 31 spline posi.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
28 spline are phased out in 05 or 06? 31 is much more readily available. You can get a new 31 spline Ford carrier, not possible for 28 spline unless you find NOS. You certainly get a used 28 spline unit and new 28 spline axles. Either way for axles I say get USA made (not Dorman) if you can. Of course you can get used axles also.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
