How can i make a cold air intake for my 98 GM, K&N wants almost $500 dollars and that is there set up for an 04 MM so I dont even know if that would fit any suggestions and/or other ways to let my baby breathe a bit easier?
cold air
The stock location is about as cool as you can get.
I'm able to see my intake air temperature, taken at the MAF, and it reads within 5° of ambient when moving.
Insulating the airbox may improve the heat soak when idling.
Anything post-MAF for a Marauder will not work on your car.-Michael
ADTR = http://www.angryducktofuracing.com
Yes the MM airbox will fit in a 98. You can get the MM airbox and MAF combo for about $150. You would need a computer tune or chip also, but they are well worth it.2000 Mercury Grand Marquis LS HPP.
http://www.cardomain.com/ride/2336322
Friends don't let friends drive donk.
