Directional Cherry Bombs?
    Thanks man. The cats are coming off my car so it will probly be a tad louder... I Appoligze for thread jacking.
      Originally posted by marquisman View Post
      Here is a quick little vid I took in the fall. Its complete with belt squeak and all
      sounds pretty sick mang!
      2010 Toyota Camry "Traveller II "
      54,xxx miles. New daily driver
      2001 Lincoln Town Car Signature "Leroy"
      rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
      114k miles. Sold to my coworker.
      1998 Toyota Camry "Traveller"
      Dead and sold.
        Originally posted by 88Vic View Post
        I'd rather had a deeper rumble or smooth tone on a V8, I prefer the snap crackle and pop on a 6 cylinder, either a divorced dual V6 or split manifold inline 6, with small 2" pipe straight or louvered glasspacked.
        As far as I know the cheaper Summit and Flowtech glasspacks are louvered and Cherry Bomb and Thrush use perforated cores.
        its pretty smooth when im drivinn it normal. i dont normally get the crackle and pop unless im revvin it around the limiter.
        Dead and sold.
          my 26 inch glass packs were on a kind of odd side, they were same size, but inside they were different, they both had perforated louvers inside wich i stuck the higher end towards the engine, and one was straight while the other was a spiral inside gave it a unique tone,almost deisely but not quite. i liked em they were 14 bucks a piece. i liked the way they sounded, but then again i also had bbk shorties with no cats too lol.
            I really only like glasspacks on engines that run cooler like carbed engines. If you run a 160 degree t-stat and place the 'packs as far back as you can they shouldn't burn out so they always have a decent sound. A friends of mine is building a '29 Ford Coupe with a flathead V8 and he might put glasspacks on it, which I think would sound great since it won't run hot enough to burn the packing out.
