alright so my marquis is running shitty again, it seams like its the low speed idel, it stalls when it sits at idel when i rev it up its fine, i put a littel air filter on my trans vacuum line cuz i put a new cold air intake kit on could this have messed it up, or i also took my car camping and got gas at a convenience/gas store, years ago i got gas in my parents van and had the same symptoms,any ideas lads? if pictures would help i can post some
o great this again
IAC/IAC Ports???
there is no trans vacuum line. Exactly what did you put an air filter on? If you unhooked one of the two stock tubes that went from the air intake pipe to the motor, that won't work. Those tubes need to attatch to the air intake pipe between the throttle body and the MAF sensor or it will not run correctly.86 Lincoln Town Car (Galactica).
Which vacuum line??
If his car is a 92-95, then it was the IAC vacuum line.
03 Mercury Marauder- 63k
