ALCON-
Took a look at the install, plan to attempt this weekend. Looks like there are some electrics running to the plenum from the fuel pressure regulator, a red wire and maybe a black. I didn't look too much, but they are running to an input on the same side of the plenum as the PCV input. The Trickflow plenum does not have that particular input port. Anyone else encounter this? Is this a ground? How did you fix it?
